| ![]() SG-17B SHDSL modemProduct designationSG-17B SHDSL modem for traffic transmission between Ethernet and SHDSL interfaces.Sections:Technical characteristics
Rate table
DescriptionSG-17B SHDSL modem is considered to be the fastest among similar devices, the transfer rate reaching 15 296 kbit/s over single pair. The modem features an extended operating distance compared to that of g.shdsl.bis in the diapason under 5.7 Mbit/s. SG-17B SHDSL modem is designed to unite distributed local networks, link up remote machines and Ethernet-featuring devices. The modem allows transmitting the VLAN IEEE 802.1Q tags either via SHDSL or Ethernet. SG-17B SHDSL modem may be used both for connections in symmetric-pair mode and for linking-up to central access units based either on SG-17AM, which functions as a 16 SHDSL ports DSLAM, or on SG-17R, which functions a router. Up to 6 SHDSL ports may be linked to a single SG-17R based on the SG-17R-1RU-CP1-4ETH platform. Up to 8 SHDSL ports may be linked to a single SG-17R based on the SG-17R-1RU-CP2-3SFP platform.
The modem configuration of the Master modem is carried out via switches, USB-port or via RS232 for special design. When linked to SG-17AM or SG-17R the modem functions as Slave modem. Configuration of linear parameters of the Salve modem runs automatically in accordance to the Master settings. SG-17B SHDSL modem enables reception of different parameters of the SHDSL channel via the EOC control channel. If the modem is linked to the SHDLS module of the SG-17R, installed on the base platform, complete automatic remote setting up of the connection line is possible. In this case the Master modem may be set up from any remote location, where network connection to SG-17R is available, and information on statistic gathering is available via SNMP, web-interface or console, installed of the base platform. SG-17B SHDSL modem default kit features 3.3V local powering from 220V ac adapter. Additional modifications with different powering:
Modem design:
Usage examplesLinking a group of local and remote IP-cameras to the network over commutator![]() Usage example description Purpose: linking different IP-cameras to information network over different interfaces. The cameras are linked to a standard PoE-featuring Ethernet commutator. The remote Ipcam-20PD/Ipcam-04PDN Sigrand IP-camera is linked over SG-17B SHDSL modem. Remote arbitrary IP-camera is linked over two SG-17B SHDSL modems. Transfer rate on the line for remote link-up reaches 15296 kbit/s over single pair. Local arbitrary IP-camera is linked to the commutator over PoE. Using in usage example products and product groups SG-17B SHDSL modem,
Uniting Ethernet networks using SHDSL, up to 15.2 Mbit/s over single pair![]() Usage example description Purpose: uniting remote points (single computers or local Ethernet networks) over bridge link with shared addressing. Transfer rate over single pair reaches 15296 kbit/s. SG-17B allows translating VLAN IEEE 802.1Q tags either over SHDSL or over Ethernet interfaces. Using in usage example products and product groups SG-17B SHDSL modem,
Linking users and networks to central access point for «Ethernet» and «E1 + Ethernet» mixed traffic transmission using SHDSL![]() Usage example description Purpose: setting up company-wide central access node to unite several remote Ethernet networks or single computers and connecting E1/G.703-featuring equipment. Several DSL interfaces of SG-17R may operate simultaneously in different modes, thus completing data multiplexing, data routing and acting as a firewall. Transfer rate over each pair reaches 14080 kbit/s. Up to 3 E1 modules may be installed, single DSL module used. The max capacity of one E1 module (MR-17G*) is 8 channels. Up to 6 DSL pairs may be simultaneously linked to a single SG-17R.
Module MR-17G1,
Module MR-17G2,
Module MR-17G4,
Module MR-17H1P2,
Module MR-17H2,
View all usage examplesSoftwareWindows driver for setting up terminal when linked over USB: stmcdc.inf. Windows X64 driver for setting up terminal when linked over USB: vcpdriver_v1.1_setup.exe. DocumentsUser's guide is available here (PDF). CertificatesThe Sigrand SG-17B SHDSL modem holds the “Declaration of conformity” issued by the Federal Communications Agency of the Russian Federation on October 8, 2008, №DTS-2553 Price and warrantyWarranty5 yearsPrice
