Linking a group of local and remote IP-cameras to the network over commutator
Usage example description Purpose: linking different IP-cameras to information network over different interfaces. The cameras are linked to a standard PoE-featuring Ethernet commutator. The remote Ipcam-20PD/Ipcam-04PDN Sigrand IP-camera is linked over SG-17B SHDSL modem. Remote arbitrary IP-camera is linked over two SG-17B SHDSL modems. Transfer rate on the line for remote link-up reaches 15296 kbit/s over single pair. Local arbitrary IP-camera is linked to the commutator over PoE.
Using in usage example products and product groups SG-17B SHDSL modem,
Uniting Ethernet networks using SHDSL, up to 15.2 Mbit/s over single pair
Usage example description Purpose: uniting remote points (single computers or local Ethernet networks) over bridge link with shared addressing. Transfer rate over single pair reaches 15296 kbit/s. SG-17B allows translating VLAN IEEE 802.1Q tags either over SHDSL or over Ethernet interfaces.
Linking users and networks to central access point for «Ethernet» and «E1 + Ethernet» mixed traffic transmission using SHDSL
Usage example description Purpose: setting up company-wide central access node to unite several remote Ethernet networks or single computers and connecting E1/G.703-featuring equipment. Several DSL interfaces of SG-17R may operate simultaneously in different modes, thus completing data multiplexing, data routing and acting as a firewall. Transfer rate over each pair reaches 14080 kbit/s. Up to 3 E1 modules may be installed, single DSL module used. The max capacity of one E1 module (MR-17G*) is 8 channels. Up to 6 DSL pairs may be simultaneously linked to a single SG-17R.
Module MR-17G1,
Module MR-17G2,
Module MR-17G4,
Module MR-17H1P2,
Module MR-17H2,
Linking subscribers and networks to central access point using SHDSL
Usage example description Purpose: linking remote points (single computers or local Ethernet networks) to the central network over bridge link with shared addressing mode or over internetwork connection with routing rules. Transfer rate over each pair reaches 14080 kbit/s. Up to 6 clients may be linked to a single SG-17R device based on the SG-17R-1RU-CP1-4ETH platform. Up to 8 clients may be linked to a single SG-17R device based on the SG-17R-1RU-CP2-3SFP platform. Up to 16 clients may be linked to a single SG-17R device in DSLAM mode. In order to link super-remote clients it is possible to use additional SG-17E regenerators with local or remote power supply. The line is powered over MR-17H*P SHDSL module. SG-17B or SG-17BP compact size modem may be used as a remote modem, having an option to receive remote power supply from information line.
SHDSL модем SG-17B-P-M,
SG-17BP SHDSL modem,
Module MR-17H1P2,
Module MR-17H2,
Linking subscribers and networks to central access point using wireless, optic or wire technologies
Usage example description Purpose: linking remote points (single computers or local Ethernet networks) to the central line over bridge link with shared addressing mode or over internetwork connection with routing rules through wireless or gigabit Ethernet interfaces of SG-17R. WiFi or WiMAX modules or plug-in gigabit SFP interfaces may be used as additional interfaces.
Module MR-17H1P2,
Module MR-17H2,
Linking remote Sigrand IP-cameras to the network over SHDSL
Usage example description Purpose: linking the Sigrand IPcam-20PD/IPcam-04PDN IP-camera to the information line over great distance through SHDSL interface. The camera is linked to the SHDSL interface of the SG-17B modem. Transfer rate on the line reaches 15296 kbit/s over single pair. The camera is powered locally.
Using in usage example products and product groups IPcam-1,2/DM368/MT9M034/D,
SG-17B SHDSL modem,
Linking remote arbitrary IP-camera to the network using SHDSL
Usage example description Purpose: linking an arbitrary Ethernet-featuring IP-camera to information line over great distance through SG-17B SHDSL modem. The camera is linked to the Ethernet interface of SG-17B. Transfer rate on the line reaches 15296 kbit/s over single pair. The camera is powered locally.
Using in usage example products and product groups IPcam-1,2/DM368/MT9M034/E,
SG-17B SHDSL modem,
