Module MR-17H2P2 is designed to be installed on the universal multiservice SG-17R platform as SHDSL channel-forming equipment
Module MR-17H2P2 provides remote power supply to regenerators, modems and IP-cameras over information line
- G.SHDSL linear interface parameters
- Number of interfaces: %%количество портов на модуле%%
- Interface type: G.SHDSL (ITU-T G.991.2.bis recommended)
- Link type: point-to-point
- Number of wires per line: 2 (one pair)
- Transfer rate, kbit/sec: 64 – 14080
- Linear code: ТС-РАМ 192
- Connection type: FDx
- Compatibility: SG-17, SG-17+
- System Interface parameters
- Electric butting type: PCI
- Bus-Master mode: available
- Maximum number of modules installed on SG-17R-1RU-CP1-4ETH base platform: 3
- Maximum number of modules installed on SG- SG-17R-1RU-CP2-3SFP base platform: 4
- Other characteristics
- Module size (with the lath):
- height, mm: 20
- width, mm: 164
- depth, mm: 125
- Weight, g:
- Power consumption, W: %%потребление%%
- Service conditions
- installed on the SG-17R base platform
- Air temperature: 10 – 40°С
- Relative humidity: up to 85%
- Air pressure: 84 – 107 kPa
- Remote power supply
- Remote power supply: available
- Remote power supply value, V: 240
- Reboot indicator: available
- Reboot at, mA: 70
- Offset indicator: available
- Offset at, V: 30
- Max power consumption for regenerators with remote power supply: 20 W per channel
- Service traffic
- ST mode support: available
Rate table
Rate, kbit/s | 0.5 mm cable, km | 0.9 mm cable, km (*) | 1.2 mm cable, km (*) | 14080 | 1,0 | 3,6 | 5,8 | 12800 | 1,2 | 3,8 | 6,4 | 11520 | 1,4 | 4,2 | 6,4 | 10240 | 2,0 | 4,6 | 7,2 | 9216 | 2,2 | 4,8 | 7,4 | 8192 | 2,4 | 5,0 | 8,0 | 7168 | 3,0 | 5,4 | 8,4 | 6144 | 3,4 | 6,0 | 9,0 | 5696 | 3,6 | 6,8 | 10,6 | 5120 | 3,8 | 7,2 | 12,0 | 4608 | 4,0 | 7,4 | 13,0 | 4096 | 4,4 | 8,0 | 14,0 | 3072 | 5,0 | 9,0 | 15,8 | 2304 | 5,4 | 10,6 | 17,0 | 2048 | 6,2 | 12,6 | 19,4 | 1536 | 7,0 | 14,8 | 22,2 | 1024 | 7,8 | 17,0 | 26,0 | 768 | 8,4 | 18,4 | 28,0 | 512 | 9,0 | 19,8 | 30,0 | 384 | 9,6 | 21,2 | 32,0 | 192 | 10,4 | 23,0 | 35,0 | | (*) - not all data obtained expermentally. |
Usage example description Purpose: uniting two Ethernet networks to reach full output in the link by using the bonding mode. In this scheme SG-17R provides either internetwork connection between two Ethernet groups with routing rules or bridge link with shared addressing of the networks united. Transfer rate over each pair reaches 14080 kbit/s. Different transfer rate may be set up in different pairs. It is important that even if on one of the pairs there is a link loss, the performance of the channel does not fail. Up to 6 pairs may be simultaneously linked to a single SG-17R device for SHDSL links based on SG-17R-1RU-CP1-4ETH platform. Up to 8 pairs may be simultaneously linked to a single SG-17R device for SHDSL links based on SG-17R-1RU-CP2-3SFP platform. Besides, in the bonding mode it is possible to unite any kind of channel-forming equipment, through which IP-traffic is transferred: E1, RS-232. Both Ether-HDLC and PPP-multilink may be chosen as protocols.
Using in usage example products and product groups (
Module MR-17G1,
Module MR-17G2,
Module MR-17G4,
Module MR-17H1P2,
Module MR-17H2,
Module MR-17S2C,
Module MR-17S2T,
Module MR-17S4C,
Usage example description Purpose: splitting the users’ traffic in the shared physical medium of data transfer. The SG-17R device supporting VLAN technology allows uniting LAN 1 and LAN 2 networks independently. Up to 4 Ethernet networks may be simultaneously linked to a single SG-17R. Each Ethernet port may be set up so as to transfer either the whole traffic or single packets with a certain VLAN number. Transfer rate over each pair reaches 14080 kbit/s. Up to 6 pairs may be simultaneously linked to a single device based on SG-17R-1RU-CP1-4ETH platform. Up to 8 pairs may be simultaneously linked to a single device based on SG-17R-1RU-CP2-3SFP platform. Using in usage example products and product groups (
Module MR-17H1P2,
Module MR-17H2,
Usage example description Purpose: linking remote points (single computers or local Ethernet networks) over bridge link with shared addressing mode. Transfer rate over single pair reaches 15296 kbit/s. SG-17B allows translating VLAN IEEE 802.1Q tags either over SHDSL or over Ethernet interfaces. The SG-17BP modem receives remote power from the line from SHDSL modules, installed on SG-17R or SG-17AM DSLAM.
Using in usage example products and product groups SHDSL модем SG-17B-P-M,
SG-17BP SHDSL modem,
Module MR-17H1P2,
Module MR-17H2P2,
The Module MR-17H2P2 holds the “Declaration of conformity” issued by the Federal Communications Agency of the Russian Federation on November 8, 2008, №DTS-2563.
years
Product name |
Quantity (pc.) |
Price in USD |
Price in FOB USD:
Total |
order
